[AG-TECH] AG2.1.2 patch not working?
Ivan R. Judson
judson at mcs.anl.gov
Fri Oct 24 09:46:05 CDT 2003
I have replicated the error, which culminates with an import error:
ImportError: cannot import name ProxyGen
Mike, if you can confirm this is the error, then just install the full
installer (over your existing install) -- that should fix it. I've made the
patch unavailable until I can figure out why this is happening. All
indications are it should work; I'm tracking this down now.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Robert Olson
> Sent: Friday, October 24, 2003 9:03 AM
> To: Michael Daw; Thomas D. Uram
> Cc: AG Technical Developers
> Subject: RE: [AG-TECH] AG2.1.2 patch not working?
> At 08:54 AM 10/24/2003, Michael Daw wrote:
> >I tried this. The window closes itself before I get a chance
> to read it
> >(let alone copy and paste it).
> You should be able to do this: bring up a regular command
> window, and run
> "\Program Files\Access Grid Toolkit\bin\VenueClient.py" -d
> It'll want the quotes.
> --bob
