[AG-TECH] Problems getting started with AG2.1
Robert Olson
olson at mcs.anl.gov
Wed Oct 22 11:18:49 CDT 2003
is that cert & signing policy available online somewhere? I'd like to try
importing those here to see if there's something weird going on (I don't
like the loss of the leading zero; as far as I know there's nowhere that
shoudl be treating those names like numbers..).
thanks
--bob
At 05:23 PM 10/22/2003 +0100, pns at soc.soton.ac.uk wrote:
>Hmm, not that simple .....
>Robert Olson <olson at mcs.anl.gov> wrote on 22/10/2003 16:49:35:
> > At 04:54 PM 10/22/2003 +0100, pns at soc.soton.ac.uk wrote:
> > >Re the CA certs in /Documents and Settings/<username>/Application
> > >Data/AccessGrid/trustedCACerts - ... interesting. The e-Science CA
>cert
> > >is there, but not the signing policy. I'll copy it over manually & see
> > >what happens ....
> > Ah, that'd cause a problem. Did you select the signing policy's path
>when
> > you did the import of the CA certs? (it brings up two file browsers, one
> > for the cert, one for the policy file. It's confusing, and I'm going to
> > change that interface for the next release).
> > --bob
>I believe I did select that path when importing the cert, I recall the two
>browser windows.
>The CA cert is in filename 01621954.0 and the signing policy is
>01621954_signing_policy (I've checked this on our Globus system)
>As I mentioned, the signing policy was absent from
>../AccessGrid/trustedCACerts, so I copied it over again.
>On starting up the venue client, I got the same problem as before.
>When I looked at the files in the trustedCACerts dir, I find that the
>01621954_signing_policy file has disappeared, and the CA cert filename has
>now lost it's leading zero to become 1621954.0
>I've tried copying back new versions of the cert & signing policy starting
>with the leading zero, and re-running the client, and the same happens.
>I've tried having two copies of each of the cert & signing policy, one
>pair with the leading zero, and one without - and the same happens, I get
>the error about invalid passphrase, and all I'm left with in the
>trustedCACerts dir is the file which is now called 1621954.0 and the
>normal two AG CA certs & their signing policies.
>All a bit mysterious!!
>Got to go now but if I get time later I'll try deleting & reimporting the
>CA cert etc.
>THanks for your help
>Phil
