[AG-TECH] Problems getting started with AG2.1
    pns at soc.soton.ac.uk
    Wed Oct 22 11:23:43 CDT 2003
Hmm, not that simple .....
Robert Olson <olson at mcs.anl.gov> wrote on 22/10/2003 16:49:35:
> At 04:54 PM 10/22/2003 +0100, pns at soc.soton.ac.uk wrote:
> >Re the CA certs in /Documents and  Settings/<username>/Application
> >Data/AccessGrid/trustedCACerts -  ... interesting. The e-Science CA
cert
> >is there, but not the signing policy.  I'll copy it over manually & see
> >what happens ....
> Ah, that'd cause a problem. Did you select the signing policy's path
when
> you did the import of the CA certs? (it brings up two file browsers, one
> for the cert, one for the policy file. It's confusing, and I'm going to
> change that interface for the next release).
> --bob
I believe I did select that path when importing the cert, I recall the two
browser windows.
The CA cert is in filename 01621954.0  and the signing policy is
01621954_signing_policy (I've checked this on our Globus system)
As I mentioned, the signing policy was absent from
../AccessGrid/trustedCACerts, so I copied it over again.
On starting up the venue client, I got the same problem as before.
When I looked at the files in the trustedCACerts dir,  I find that the
01621954_signing_policy file has disappeared, and the CA cert filename has
now lost it's leading zero to become 1621954.0
I've tried copying back new versions of the cert & signing policy starting
with the leading zero, and re-running the client, and the same happens.
I've tried having two copies of each of the cert & signing policy, one
pair with the leading zero, and one without - and the same happens, I get
the error about invalid passphrase, and all I'm left with in the
trustedCACerts dir is the file which is now called 1621954.0  and the
normal two AG CA certs & their signing policies.
All a bit mysterious!!
Got to go now but if I get time later I'll try deleting & reimporting the
CA cert etc.
THanks for your help
Phil
