[AG-TECH] ag2.1.2.b rat problems
Mike Elmore
mwelmore at lbl.gov
Mon Oct 20 12:11:09 CDT 2003
I tried to set up our node this morning and it appears we are having
a little difficulty with the new software. If I start the venue client
in both machines I can get a new certificate for both the vic and the
display/audio machine. However, I could not get the audio to work
after going to the new room. The rat did show up this time. The only'
way I could get the client to open and then go into the room was to
reboot the display/audio machine.
I would appreciate any help.
Thank you myk for the info about getting into the ncsa lobby.
Mike
Mike Elmore wrote:
> We have installed the beta version on a windows 2000 machine (for
> display and audio)
> and a linux machine for the video producer. We have it working.
> However, when the
> venue client is closed, the rat will not start. I have to go in and
> delete the node
> configuration from the folder and go back into the setup wizard and
> build the node again.
> It will continue to work (I will verify this on Monday) as long as the
> client is still open.
> Any ideas?
> Thank you,
> Mike
Type: text/x-vcard
Desc: Card for Mike Elmore
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031020/2f5f74b4/attachment.vcf>
