[AG-TECH] Question on AG 2 install
Ivan R. Judson
judson at mcs.anl.gov
Fri Oct 17 10:33:52 CDT 2003
In the latest release (2.1.2 which is on it's way out the chute) the
directory is checked for and created if it's not there. The file is a log
file from the service manager, it shows up if the service manager
successfully starts.
-Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Russ Wolf
> Sent: Friday, October 17, 2003 9:42 AM
> To: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Question on AG 2 install
> What about the ~/.AccessGrid/ directory and the agsm.log file ?
> Are these checked for and created if they don't exist in the current
> file set ?
> -Russ
> Thomas D. Uram wrote:
> > The directory must exist, but it is used as a temporary
> directory by
> > the
> > software. It does not rely on any files being there
> already, so you
> > don't need to copy the service files there.
> > For the record, the problem with that directory not
> existing has been
> > fixed in cvs.
> > Tom
> > Rabarison Monika Klara wrote:
> >> and in that directory I put a copy of AudioService.zip and
> >> VideoConsumerService.zip from /usr/share/AccessGrid/services
> >> Monika
> >> On Fri, 17 Oct 2003, Michael Daw wrote:
> >>> Yup - just make the directory /tmp/local_services if I remember
> >>> rightly.
> >>>> [mailto:owner-ag-tech at mcs.anl.gov]On
> >>>> Behalf Of A Quay
> >>>> Sent: 17 October 2003 02:25
> >>>> Subject: [AG-TECH] Question on AG 2 install
> >>>> Has anyone had this problem on a three machine node
> (WinXP, RH 7.3,
> >>>> RH 7.3)?
> >>>> On the last screen of the Node Configuration Wizard when
> saving the
> >>>> final settings, the audio and video machines debug print this
> >>>> error:
> >>>> Exception in AddService, retrieving service implementation
> >>>> -- exceptions.IOError (Errno 2] No such file or directory:
> >>>> '/tmp/local_services/AudioService.zip'
> >>>> and error of VideoProducerService.zip on video machine.
> >>>> -andy
> >> Monika Rabarison
> >> Systems Administrator
> >> Office of Information Technology/HPCVI
> >> Jackson State University
> >> Office:(601)979-5933
> >> SciVis Lab:(601)979-1061
> >> JSUvisNode:(601)979-1056
