[AG-TECH] A new install error message...
    Singletary, Abraham
    SINGLETARYA at MAIL.ECU.EDU
    Fri Oct 10 12:03:54 CDT 2003
Hello everyone,
This is the current error message that I'm getting from a new install of
2.1.
The computer network configuration is not correct. To correct the problem,
"by setting the Globus_Hostname environment variable" and restart the app.
Application will exit "Globus_Hostname is configured, but is not set in the
process.  If you started this program from a command window, you may have to
start a new command window to run with the proper setting."
I have not started the program from a command prompt.  I have completed 1
successful install; however; I have been working with this one for more than
a week now..
Abe Singletary
Consultant
(w) 252-328-9130
 <mailto:singletarya at mail.ecu.edu> singletarya at mail.ecu.edu
 <http://www.ecu.edu/itcs/act> www.ecu.edu/itcs/act
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031010/e9bd7ad2/attachment.htm>
