[AG-TECH] Gentner wiring question
Robert Olson
olson at mcs.anl.gov
Fri Oct 10 15:50:41 CDT 2003
At 02:46 PM 10/10/2003 -0600, Darin Oman wrote:
>Hello,
>I'm attempting to set up our old Gentner AP-400 to work with our portable
>node. The problem is, I've never done this. I found some documentation
>that tells me to "Connect outputs C and D of the Gentner to the left and
>right speaker." There's also a standard speaker connection on the Gentner
>(ground and voltage). Why not use these?
The speaker connection is for the internal amp that the AP400 has; if you
want you can use that. If you have powered speakers, however, you should
use the outputs as described in the doc.
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031010/7f3ef674/attachment.htm>
