[AG-TECH] linux not recieving own vic stream
    Jason Hill
    jahill at scl.ameslab.gov
    Fri Oct 10 11:08:38 CDT 2003
Frank - are you seeing a vic window with all the other video streams in
the venue? I know that on our linux setup all the streams are muted on
the capture box - while the streams on the display box are displayed.
also - if you are executing the vic command by hand try using the -D
flag and specifying the device. I have had success with viewing a local
stream in a venue that way.
for example:
vic -D /dev/video2 address/port
Hope that helps.
-Jason
Jason Hill
Scalable Computing Laboratory, Ames Laboratory
310 Wilhelm Hall
Ames, IA 50010
Frank Sweetser wrote:
> On Fri, Oct 10, 2003 at 09:51:21AM -0400, Jennifer Teig von Hoffman wrote:
>>Hi Frank,
>>Somebody said something the other day on the MOO about this being normal
>>behavior in linux. I'd never seen it before myself, though. I'm assuming
>>you hadn't either in earlier versions of AG?
> Actually, I haven't had much luck getting AG working under linux before this =)
