[AG-TECH] How to get certificate file userkey.pem for Redhat system
Ziru Zhu
ziru at cc.gatech.edu
Thu Oct 2 11:15:05 CDT 2003
Hello Vu,
I did that under redhat 9.0. The userkey.pem should be generated by the
grid-cert-request. What version of AGTk are you using? I used the one
checked out from the CVS and it works.
Ziru
Ziru Zhu
College of Computing
Georgia Institute of Technology
On Fri, 3 Oct 2003, Vu Quang Minh wrote:
> Thank you for your answer, but I did put the file usercert.pem into the
> directory ~/.globus/ and the error message (segmentation error) came up.
> > On Tue, 30 Sep 2003, Vu Quang Minh wrote:
> > > I am Vu Quang Minh at The University of Tokyo.
> > > I have installed Access Grid 2.1.1 into 2 Redhat 8.0 machines
> > > and 1 Windows machine. I could get a globus certification
> > > for the Windows machine using the automatic request procedure
> > > inside it, but I could not get the globus certification
> > > for the Redhat Linux machines. The version of Access Grid 2.1.1
> > > for Redhat system does not have an automatic request procedure
> > > so I have had to use grid-cert-request command to generate 2 files:
> > > usercert_request.pem and userkey.pem. I have sent the detail of
> > > the file usercert_request.pem to the address leggett at mcs.anl.gov
> > > in order to get the file usercert.pem. When I received usercert.pem
> > > file I has been altered that I should use the automatic request
> > > procedure for Access Grid 2.1.1 (but I do not know how to get
> > > usercert.pem automatically in Redhat). Instead of that warning, I
> > > have tried out the usercert.pem file but I have catch up with
> > > "segmentation error".
> > > Has anyone installed Access Grid 2.1.1 in Redhat 8.0 system and get the
> > > file usercert.pem successfully?
> > > Vu Quang Minh <vuminh at mlab.t.u-tokyo.ac.jp>
> > Put the usercert.pem under ~/.globus directory and you should be all set.
> > Ziru Zhu
