[AG-TECH] How to get certificate file userkey.pem for Redhat system
Ziru Zhu
ziru at cc.gatech.edu
Thu Oct 2 10:01:11 CDT 2003
On Tue, 30 Sep 2003, Vu Quang Minh wrote:
> I am Vu Quang Minh at The University of Tokyo.
> I have installed Access Grid 2.1.1 into 2 Redhat 8.0 machines
> and 1 Windows machine. I could get a globus certification
> for the Windows machine using the automatic request procedure
> inside it, but I could not get the globus certification
> for the Redhat Linux machines. The version of Access Grid 2.1.1
> for Redhat system does not have an automatic request procedure
> so I have had to use grid-cert-request command to generate 2 files:
> usercert_request.pem and userkey.pem. I have sent the detail of
> the file usercert_request.pem to the address leggett at mcs.anl.gov
> in order to get the file usercert.pem. When I received usercert.pem
> file I has been altered that I should use the automatic request
> procedure for Access Grid 2.1.1 (but I do not know how to get
> usercert.pem automatically in Redhat). Instead of that warning, I
> have tried out the usercert.pem file but I have catch up with
> "segmentation error".
> Has anyone installed Access Grid 2.1.1 in Redhat 8.0 system and get the
> file usercert.pem successfully?
> Vu Quang Minh <vuminh at mlab.t.u-tokyo.ac.jp>
Put the usercert.pem under ~/.globus directory and you should be all set.
Ziru Zhu
