[AG-TECH] vic fact
Andrew Swan
aswan at cs.berkeley.edu
Tue Nov 18 10:43:53 CST 2003
Robert Olson wrote:
> What is happening is that rat uses the same port number for the source port
> and destination port, but vic uses a randomly-assigned port number for its
> source port.
> I've poked a little about changing this behavior in vic, but the
> straightfoward fixes I've tried haven't changed it; looks like it'll be
> more important as time goes on to get this taken care of - after SC perhaps
> I'll try to take another stab at it.
mash vic has an option to use the same port numbers, it is
enabled with the -rtptv flag to vic (it is so named since
rtptv also relies on matching port numbers). the network
code in uclvic and mash have diverged a bit over the years
but the fix from mash could probably be ported back to
agvic with a little work...
-Andrew
