[AG-TECH] AG2.0 DHCP Failure?
LWBelknap at lbl.gov
Thu May 22 13:27:45 CDT 2003
It appears that we have a problem with Globus Certification and our
DHCP implimentation when trying to start "Access Grid Venue Client". I
am running a Pig w/ WinXP OS. I have received and installed the
Certificate ok. (Not sure why I was not able to get a new "Grid Proxy
Init", but i re-installed keys from backup and works again.
Now when I start the "Access Grid Venue Client" I get the following
windows and error infromation:
Globus network problem
This computer's network configuration is not correct.
We will invoke the network configuration tool, and the
Venues client will then exit. Complete the configuration and
restart the Venues client.
OK
C:\Python22\python.exe
setting flag 536872960
Found interfaces:
{'ip': '128.3.3.100', 'hostname': '100.3.3.128.in-
addr.dhcp.lbl.gov', 'name':
'Local Area Connection 3', 'dns': '128.3.34.186'}
{'ip': None, 'name': 'Local Area Connection', 'dns': None}
skipping interface {'ip': None, 'name': 'Local Area
gethostbyname failed for host aglwb.lbl.gov
Traceback (most recent call last):
File "C:\PROGRA~1\WINGLO~1\config\globus_init.py", line 795, in
ThreadQueryFun
c
myIP = socket.gethostbyname(self.myfqdn)
gaierror: (7, 'getaddrinfo failed')
Setup Wizard
Check Network
Choose the network interface to use for incoming connections
IP Address Hostname Description
128.3.3.100 100.3.3.128.in-addr.dhcp.lbl.gov Local Area
Connection 3
^ Set GLOBUS_HOSTNAME environment variable to 100.3.3.128.in-
addr.dhcp.lbl.gov
<Back Finish Cancel
When I click "Finish", the opened Dos window then quickly scrolls more
data and closes before I cn read it. Much less coppy it. On retrying
the "Access Grid Venue Client", I repeat the error messages and setup.
