[AG-TECH] Testing multicast connectivity...
Richard Coffey
richardc at cs.utah.edu
Tue May 20 21:59:46 CDT 2003
I was referring to both problems. The Cisco bug might be a problem as well,
but I think most of our core routers have been upgrade beyond this problem.
I'll check with our NOCC on the IOS revs.
Thanks Bill and Mitch!
-Richard
On 5/20/03 8:24 PM, "Bill Nickless" <nickless at mcs.anl.gov> wrote:
> Ah, this is a different problem. I thought you were talking about the
> beacon traffic not being heard by other beacons. Now I understand you're
> talking about your beacon crashing from time to time (or one of the three
> threads).
> Mitch Kutzko <mitch at ncsa.uiuc.edu> has a slightly modified version of the
> beacon code, with larger pre-compiled constant buffers. I'm not sure if
> Mitch thinks it's ready for prime time yet. I've copied him on this
> note--Mitch, is it ready for distribution?
> At 05:12 PM 5/20/2003 -0600, Richard Coffey wrote:
>> Hi Bill,
>> Avtwo.cs.utah.edu is the beacon is question. Every once and a while, Java
>> throws and exception and kills the connection. Thoughts on that?
>> -Richard
>> On 5/20/03 4:15 PM, "Bill Nickless" <nickless at mcs.anl.gov> wrote:
>>> This is consistent with an old bug in Cisco IOS prior to 12.0(10). If the
>>> router directly connected to the source is running an earlier version, then
>>> the behavior you mention below is possible.
>>> What specific beacon sources are you referring to?
>>> At 03:57 PM 5/20/2003 -0600, Richard Coffey wrote:
>>>> Hi all,
>>>> As of late, I've noticed problems with individual multicast addresses
>>>> working. The beaconserver's address seems to indicate that we cannot send,
>>>> yet I've gone into the test room and successfully collaborated. Also,
>> people
>>>> cannot see me in a particular room, but in other rooms they can, and vice
>>>> versa.
>>>> We're not running tight ACL's on our routers, so it's not that. Thoughts?
>>>> -Richard
>>>> Richard C., SCI Evangelist
>>>> SCI Institute
>>>> University of Utah
>>>> http://www.sci.utah.edu/
>>>> 801.918.5050
>>>> 801.585.6513 fax
>>> Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252
>> 7390
>>> PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74
>> F7 nickless at mcs.anl.gov
> Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
> PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
