[AG-TECH] Testing multicast connectivity...
Richard Coffey
richardc at cs.utah.edu
Tue May 20 18:12:31 CDT 2003
Hi Bill,
Avtwo.cs.utah.edu is the beacon is question. Every once and a while, Java
throws and exception and kills the connection. Thoughts on that?
-Richard
On 5/20/03 4:15 PM, "Bill Nickless" <nickless at mcs.anl.gov> wrote:
> This is consistent with an old bug in Cisco IOS prior to 12.0(10). If the
> router directly connected to the source is running an earlier version, then
> the behavior you mention below is possible.
> What specific beacon sources are you referring to?
> At 03:57 PM 5/20/2003 -0600, Richard Coffey wrote:
>> Hi all,
>> As of late, I've noticed problems with individual multicast addresses
>> working. The beaconserver's address seems to indicate that we cannot send,
>> yet I've gone into the test room and successfully collaborated. Also, people
>> cannot see me in a particular room, but in other rooms they can, and vice
>> versa.
>> We're not running tight ACL's on our routers, so it's not that. Thoughts?
>> -Richard
>> Richard C., SCI Evangelist
>> SCI Institute
>> University of Utah
>> http://www.sci.utah.edu/
>> 801.918.5050
>> 801.585.6513 fax
> Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
> PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
