[AG-TECH] help with vic and rat startup - default settings
Grzesiek Sedek
grzesiek at mi2.hr
Tue May 20 08:06:22 CDT 2003
I've solved this problem, vic's tcl script had wrong permissions.
But now I wonder if there is a possibility to open video streams by
default on startup?
Thank you
On Tue, 2003-05-20 at 13:56, Robert Olson wrote:
> what do you mean video does not go out? Do you see your video in vic window
> at all? What capture device does vic show it is using?
> At 02:44 AM 5/20/2003 +0100, Grzesiek Sedek wrote:
> >Yep, it's fine, but after a while of testing with vic ant tcl script for
> >it I still don't seem to send a video to the network, all the settings
> >seem to be fine ( transmit button pressed, frame rates and the rest )
> >but video does not go out.
