[AG-TECH] help with vic and rat startup - default settings
Grzesiek Sedek
grzesiek at mi2.hr
Mon May 19 20:44:37 CDT 2003
Yep, it's fine, but after a while of testing with vic ant tcl script for
it I still don't seem to send a video to the network, all the settings
seem to be fine ( transmit button pressed, frame rates and the rest )
but video does not go out.
Anyone have a already a script for wintv go card that is tested and
running?
Thank you.
On Tue, 2003-05-20 at 00:25, Colin Perkins wrote:
> Add "*audioInputMute: 0" into $HOME/.RATdefaults (or into the appropriate
> part of the registry on Windows).
> Colin
> --> Grzesiek Sedek writes:
> >Ok I've found how to do it for vic - still no luck with rat...
> >Thanks for any pointers.
> >http://www-mice.cs.ucl.ac.uk/multimedia/software/vic/faq.html#autotrans
> >On Mon, 2003-05-19 at 21:49, Grzesiek Sedek wrote:
> >> Hello,
> >> How to set vic to pick up right source (composite pal) and start
> >> transmitting after start and rat to switch on microphone?
> >> Thank you.
