[AG-TECH] Python package not getting installed ??
Carter, Tameka
ttcarter at bnl.gov
Wed May 14 16:12:08 CDT 2003
That must be the problem I have been having with our Linux machines. I bet
that solves everything.
Tameka
-----Original Message-----
From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
Sent: Wednesday, May 14, 2003 5:09 PM
To: nikhil at east.isi.edu; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Python package not getting installed ??
Nikhil,
You really want to try and install on RH 7.3, there are a lot of buggy
issues trying to install on < 7.3.
Would you consider upgrading? It'll make your life easier, and ours. Just
ask Dave Semararro :-)
--Ivan
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of nikhil
> Sent: Wednesday, May 14, 2003 12:08 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Python package not getting installed ??
> Thanks, this problem is solved by X server access control (xhost +) !
> But the next issue is that when I was querying 'rpm -q
> python', it was showing
> the old version of pyhton even though I have installed all the python
> packages. Then I removed the old package, so that 'rpm -q
> python' does not
> show any such package installed. I reinstalled the python
> RPMs, still no
> luck, still it shows no such package installed ??
> Nikhil
> On Wednesday 14 May 2003 03:13 pm, nikhil wrote:
> > Hi,
> > After installling complete s/w on my Linux RH 7.0, I incur problem
> > while running AGNodeService.py, as :
> > [ag at schizophrenia root]$ AGNodeService.py &
> > [1] 2777
> > [ag at schizophrenia root]$ Xlib: connection to ":0.0" refused
> by server
> > Xlib: Client is not authorized to connect to Server
> > Gtk-WARNING **: cannot open display: :0.0
> > [1]+ Exit 1 AGNodeService.py
> > Seems a problem with accessing, right ??
> > Thanks,
> > Nikhil
> Computer Networks Division
> USC Information Sciences Institute
> Arlington, VA 22203
