I will be running AG 2.0 in one form or another on a few different machines (main node, my laptop, etc.). Is it OK to use the same certificate for all machines, or should I request a separate cert for each? Is there a problem if there are 2 nodes running at the same time using the same cert? Thanks, Darin
