hello, i am also having dificulty with the TVS. is your error the same error as the one i get = " venue url that you specified is not valid." this is referring to the default transitional venues server address in the Grid Proxy Init. If so, were you able to fix the error and how were you able to go about doing so. thanks a lot.
