[AG-TECH] Transitional Venues Server
Sugree Phatanapherom
g4465027 at ku.ac.th
Mon Mar 17 20:26:05 CST 2003
MessageHi all,
I'm using beta 1 and got the same problem. I tried to run Venue Server on my
side but url must be https://localhost:8000/Venues/default. Anyway,
VenueManagement recommends to use port 9000 instead.
If the port is 9000, VenueClient.py (hosting/pyGlobus/Client.py) will report
"handle is not valid" (connection refused). After changing venue port to
8000, it works fine.
However, I can't connect to TLS for both 8000 and 9000.
9000 -> connection reset by peer
8000 -> connection time out
This seems to be firewall problem but I don't sure.
----- Original Message -----
To: 'Gary Kong' ; ag-tech at mcs.anl.gov
Sent: Monday, March 17, 2003 7:34 PM
Subject: RE: [AG-TECH] Transitional Venues Server
Hi Gary,
which version of the software are you using? Can you report this via
bugzilla? If you are using beta 1 perhaps you could include all the .log
files produced by the various tools (venueclient.log in particular). This
would help us figure out what you are running into.
--Ivan
PS -- That url is the correct url for the TVS.
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Gary Kong
Sent: Monday, March 17, 2003 4:50 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Transitional Venues Server
Does anyone know the address for the Transitional Venues Server supposedly
hosted by Futures Lab as mentioned on the FAQ section of the AG toolkit
website?
I tried using https://vv2.mcs.anl.gov:9000/Venues/default, but doesn^Òt seem
to work.
Thanks.
Gary Kong
