[AG-TECH] Re: [APAG] Help installing ag software
Sugree Phatanapherom
g4465027 at ku.ac.th
Tue Mar 11 04:05:00 CST 2003
When you join any Venue, vic and rat are automatically started. Anyway, you
have to "quit" the first instance of them.
I found that ProcessManagerUnix.py attempts to kill the process by sending
SIGINT and then waitpid. For my experience, the processes don't quit at all.
I tried SIGQUIT but got the same problem. Currently, I use SIGKILL and it
works fine. If you don't want to change the code, just quit vic or rat
whenever VenueClient or NodeManagement are not responding.
> Before starting any programs, please change directory to
> /usr/share/AccessGrid
> From: "George Estes" <gestes at ncsa.uiuc.edu>
> To: "Sugree Phatanapherom" <g4465027 at ku.ac.th>; <ag-tech at mcs.anl.gov>
> Sent: Tuesday, March 11, 2003 2:13 AM
> Subject: Re: [AG-TECH] Re: [APAG] Help installing ag software
> > Did you find a solution to this problem? I'm getting the same error.
> > George
> > At 05:22 PM 3/4/2003 +0700, Sugree Phatanapherom wrote:
> > >Envelope-From: owner-ag-tech at mcs.anl.gov
> > >From: "Sugree Phatanapherom" <g4465027 at ku.ac.th>
> > >To: "Jason Bell" <j.bell at cqu.edu.au>, <ag-tech at mcs.anl.gov>,
> > > <apag at prg.cpe.ku.ac.th>
> > >Cc: <chris at vislab.usyd.edu.au>, <Dominique.Morel at jcu.edu.au>,
> > > <m.barry at qut.edu.au>
> > >Subject: [AG-TECH] Re: [APAG] Help installing ag software
> > >Date: Tue, 4 Mar 2003 17:22:38 +0700
> > >X-Mailer: Microsoft Outlook Express 6.00.2800.1106
> > >X-Spam-Level: *
> > >X-Spam-Status: No, hits=1.5 required=5.0
> > >tests=FROM_ENDS_IN_NUMS,PORN_14,WEIRD_PORT version=2.21
> > >X-Spam-Level: *
> > >Sender: owner-ag-tech at mcs.anl.gov
> > >X-MD5SUM: add6114a31e574b7227f101c50aa9f32
> > >Hi,
> > >In my opinion, you should try both AG 1.0 and AGtk 2.0 to keep track of
> the
> > >development. I wrote a brief step-by-step installation guide for later
> use.
> > >You may be interesting to read it as a guide-line.
> > >http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid
> > >Anyway, I got errors while trying to add services. Service Manager
should
> > >find AudioService in local_services but it didn't find. Then, it tried
to
> > >load the service online but again it read on wrong directory. The
correct
> > >value might be services/AudioService.zip. I guess that Service Manager
is
> > >confusing the use of local_services and services.
> > >===> cut here <===
> > >Retrieving Service Package:
> > >https://prg-34-13.cpe.ku.ac.th:62556/packages/AudioService.zip
> > >Exception in AddService, retrieving service implementation
> > >-- exceptions.IOError [Errno 2] No such file or directory:
> > >'local_services/AudioService.zip'
> > >*** Method AddService exception
> > >Traceback (most recent call last):
> > > File
>"/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py"
> > >line 3839, in do_POST
> > > fr = apply(f, args, {'_SOAPContext':c})
> > > File
> > >"/usr/lib/python2.2/site-packages/AccessGrid/hosting/AccessControl.py",
> line
> > >285, in __call__
> > > raise fault
> > >faultType: <Fault : <Fault AGServiceManager.AddService failed: [Errno
2]
> No
> > >such file or directory: 'local_services/AudioService.zip': >>
