[AG-TECH] AG2.0 Pig and quickbridge
Lloyd W. Belknap
lwbelknap at lbl.gov
Tue Jul 22 15:35:45 CDT 2003
I can not address the root cause. It should be configured in the
Preferences/manage My Node/ menu window. select "localhost 2000".
this will display the services on the right side of the window
Double click "VideoProducerService" The Rsource option should
point to your video camera driver.
(Note, anyone, step in and correct any mistakes i may have
in the understanding.)
To fix the symptom in the mean time, after you get to the desired room,
1) select the vic window,
2) click on the "menu" button bottom right.
3) Click on the"Transmit" option in the upper left.
4) Click on the Dismiss button bottom center"
This will display two local images in the vic window.
Only one will be seen remotely.
At 2:46 PM -0400 7/22/03, Steve Gallo wrote:
>Hello,
>I've installed the AG2.0 PIG on my Win2k laptop and am testing using the
>quickbridge
>to come into the test room. I can see everyone in the test room in the rat
>and
>vic, but how do I get my video to start in the test room as well? The
>quickbridge
>documentation says that I can use the vrm, but it doesn't seem to be
>included in the
>AG2.0 software.
>Steve
>Steve Gallo
>Database Administrator
>smgallo at ccr.buffalo.edu
>Center for Computational Research
>University at Buffalo, The State University of New York
>9 Norton Hall, Buffalo, NY 14260-1800
>716-645-6500 x521
