[AG-TECH] PIG and autoplace
    Thomas Uram
    turam at mcs.anl.gov
    Wed Jul 16 12:21:51 CDT 2003
In the vic startup file (specified with the -u command line switch), the
following option turns off the autoplace functionality:
option add Vic.disable_autoplace true startupFile
This option was not properly handled in previous versions of ag-vic.
The problem you describe did occur in AG2.0 prior to the release, but
has been fixed in the final AG2 release.
Tom
Randy Groves wrote:
> Is there a switch to set this?  I just got a note from Allan Spale
> saying that he's seen the same thing happen in 2.0.
> -randy
> At 09:14 PM 7/15/2003 -0500, Thomas Uram wrote:
>> Randy:
>> I don't know whether this problem has been handled in the AG1.x PIG;
>> maybe someone else can comment on that.
>> As for 2.0, the problem was corrected with a fix to ag-vic to make it
>> properly recognize a switch to "not autoplace", and use of that
>> option in the tcl script passed to vic in the VideoProducerService.
>> Tom
>> Randy Groves wrote:
>>> (I KNOW, I KNOW - I should be using AG2.0 ...)
>>> I'm trying to set up a demo and happened upon something that I
>>> hadn't seen before.  I'm using the 1.2 version of the PIG.  When I
>>> set up an autoplace and re-enter the room, I get not only the video
>>> windows from the Display Resource Manager's video tool, but I also
>>> get a window for each of the video capture vics that are running.
>>> Needless to say, this is a bit of a bother.  I'm guessing that
>>> they're all reading the vic.prefs file and reacting accordingly.
>>> Has anyone had this happen?  And do you have any workarounds?
>>> Unless this is fixed in 2.0, I'm guessing that it also happens there.
>>> -randy
