[AG-TECH] Osprey multiple stream problems
    Randy Groves
    randy.groves at boeing.com
    Wed Jul 16 10:33:53 CDT 2003
This was just a nuisance before, but now that I'm planning on showing this
off to some folks who would rather not see glitches, I'd like to see if
there's a solution - other than spending money.
I'm using two Osprey 210 capture cards in a AG node - outfitted right at
the moment with AG 1.2 in the PIG configuration.  I am getting the
complaint from the Osprey drivers that I'm trying to start up multiple
streams and if I would just spend another $500 on an update to their
drivers, they'll get rid of the problem.  This occurs when the video
capture commences - on entry into the venue.  The silly thing is, if I then
manually start the capture from the VRM, it happily starts up, and there is
no problem.  This is with the 'Allow multiple opens of each board' checked
in the configuration.  If I uncheck this option, I seem to get more
intermittent crashes of the ddvic, but I don't get the complaint.
First of all, is there a setting that I'm missing?  Or is this just the way
it works?
And second - is this fixed in 2.0?
-randy
