[AG-TECH] 'Yellow' flash in vic
    Luc Renambot
    luc at evl.uic.edu
    Thu Jul 10 17:18:37 CDT 2003
Use the force, Alan:
  c:\> start [ /HIGH | /REALTIME | /ABOVENORMAL | /BELOWNORMAL] vic .....
That would have to be added into the program/script starting vic.
Luc.
luc at evl dot uic dot edu
] -----Original Message-----
] From: owner-ag-tech at mcs.anl.gov
] [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Allan Spale
] Sent: Thursday, July 10, 2003 4:17 PM
] To: Randy Groves
] Cc: ag-tech at mcs.anl.gov; alan at cs.uic.edu
] Subject: Re: [AG-TECH] 'Yellow' flash in vic
] This would probably work great except for the fact that the
] VIC processes are started and stopped as one changes rooms,
] so it is necessary to change the priority each time after
] moving to a new room.  If there was a way to just tell
] Windows "always start VIC capture process at High", that
] would probably solve the problem.  EVL made an attempt to try
] to use batch files and to masquerade as "ddvic" when it was
] really a batch file that started ddvic with High priority,
] but mysteriously then the Video Resource Manager and Display
] Resource Manager failed to appear.  One would have to assume
] they are "hard-wired" to look for something.
