[AG-TECH] Setups for XAP400 w/ G-Ware?
    William D. Hamblen
    william.d.hamblen at dartmouth.edu
    Wed Jul  9 14:34:12 CDT 2003
Hi everyone,
I've been following this discussion with some interest since we also have
an XAP-400 with G-Ware.  As of last week I thought we had it configured
correctly: a test went well, no echo, etc.  Then yesterday we had a severe
echo problem with 2 out 3 identical mics, identically configured.  Room
placement made no difference - the same mic was always good and the other
two always had echo.  I didn't test it any further because we only needed
the one mic that day.
Anyway, if this gets taken offline I'd like to be kept in the loop.  If I
figure out what went wrong yesterday or convince myself that our setup is
still correct, I will report that here.
Randy, the breakthrough I needed was the "virtual reference" button in
G-Ware (a toolbar button that looks like a grid with a capital R on it).
It brings up a Matrix screen which lets you configure all the stuff
Allan's document talks about.
 - Bill
William D. Hamblen           email: william.d.hamblen at dartmouth.edu
UNIX Systems Specialist      phone: (603) 646-1303
Physics and Astronomy        office: Wilder 306
Dartmouth College            fax: (603) 646-1446
On Wed, 9 Jul 2003, Jennifer Teig von Hoffman wrote:
> These are good points, Randy.
> Alan, would you be able to update your document to include information
> about newer models? And if not, perhaps somebody else out there on
> ag-tech would be interested in helping out here?
> - Jennifer
> Randy Groves wrote:
> > Thanks - you're right - I've looked at your document.  But the inputs
> > and outputs on the XAP400 are slightly different, and the G-Ware
> > interface is similar, but not exactly the same as the APWare's.  I'm
> > sure that I can figure out the translation, but I was hoping that
> > someone might have already done so.
> > -randy
> > At 11:12 AM 7/9/2003 -0500, you wrote:
> >> Randy,
> >> The orginal AP400 preset instructions still seem intact.  They are still
> >> available from the AGDP document (HTML format) at
> >> http://www.accessgrid.org/agdp/howto/config-gentner-ap400/1.5/html/index.html.
> >> Allan
> >> EVL at UIC
> >> Research Assistant
> >> On Tue, 8 Jul 2003, Randy Groves wrote:
> >> > Anybody have either preset files or preset instructions for the
> >> standard AG
> >> > presets for this configuration?  The XAP400 labels the inputs and
> >> outputs a
> >> > little diffferently, and the G-ware package is somewhat different as
> >> well.
> >> > The pointers to the preset files in Allan's Gentner setup seems to have
> >> > died in the latest web move:
> >> <http://www-fp.mcs.anl.gov/ag/gentner.htm>http://www-fp.mcs.anl.gov/ag/gentner.htm
> >> > Thanks!!
> >> > -randy
