[AG-TECH] Network Flow diagrams
Andrew Shewmaker`
shewa at inel.gov
Thu Jan 30 09:29:50 CST 2003
On Thu, 30 Jan 2003 11:46:38 +0000
"Osland, CD (Chris) " <C.D.Osland at rl.ac.uk> wrote:
> I think some of the entries under "All AG Nodes" should be split
> off into "Machines running a Beacon" but haven't done that in case
> I'm wrong.
I think you are right to point out that not all hosts will be running
a beacon. I added the information for the NLANR/DAST Beacon server
to the attachment just to be thorough.
> In the same section, I have marked some lines that should perhaps
> say 'server' instead of 'client' - just a cut and paste byproduct,
> I think.
I am pretty sure those lines should say client based on the beacon
statistics web page. For instance, the NLANR/DAST page says,
"... Target Multicast Group: 233.4.200.18 ...
Client-to-Server unicast traffic on port: 9999 | Client-to-Client multicast traffic on port: 10100"
And I think the server just receives from clients and creates the
> It may be useful to tie some of the ports to the way they are set;
> e.g. the port used by DPPT seems to be settable in DPPT Server Set,
> so perhaps this connection should be recorded, as I have done for
> the X-Windows form of VNC (hopefully using the correct terminology).
> Perhaps people would like to send any comments to the list, which
> I'll pick up and incorporate as long as no-one else disagrees.
> Anyone any thoughts on the most useful form? Web table?
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and
> are for the use of the intended recipient only.
> If you are not the intended recipient do not take
> any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
Andrew Shewmaker
Associate Engineer
Phone: 208.526.1415
Fax: 208.526.4017
Idaho National Engineering and Environmental Laboratory
2525 Fremont Ave.
Idaho Falls, ID 83415-3605
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030130/9d67e944/attachment.txt>
