[AG-TECH] Network Flow diagrams
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Mon Jan 20 09:51:30 CST 2003
There was some discussion of this a few weeks ago on ag-tech.
In addition to the ones you've noted, VNC uses something like
5800+ (or 5900+) the X-windows screen number, and the archive
will probably show up a whole lot more.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Philip J McCormick [mailto:mccormick at uk.ibm.com]
Sent: 20 January 2003 12:31
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Network Flow diagrams
I've had a look in the AG docs for a diagram that shows the ports and
network protocols used by the applications running on the AG machines
(Display, Audio and Video), but I can't find one. Does anyone know the
location of such a diagram or have one they can send me?
I've knocked up a quick example of the kind of thing I need. I'll use this
one if there aren't any others out there......does it look correct?
anything missing?
(See attached file: net_flow.jpg)
Thanks
Phil McCormick
MCCORMIC at UK.IBM.COM
