[AG-TECH] RE: AGTk 2.0 alpha 3 Available
Michael Daw
mike.daw at man.ac.uk
Tue Feb 25 05:37:10 CST 2003
I'm getting a problem installing this. My problem is thus:
[root at george RPMs]# rpm -Uvh AccessGrid-2.0alpha-3.i386.rpm
error: failed dependencies:
logging is needed by AccessGrid-2.0alpha-3
Before you think I'm being (completely) stupid, I have reinstalled (updated,
actually) all the new rpms (i.e. gpt 1.0.2, data management 2.0.2, pyGlobus
2).
One difference in what I'm doing that other people may not is that I still
have to run 'rpm -Uvh --force --nodeps pyGlobus-cvs-2.i386.rpm' (bug #14) to
install pyGlobus.
Any help before I crawl my way into Bugzilla...? (By the way, Ivan, despite
your comment, you *still* haven't fixed bug #25 [not that I'm checking up on
you or anything]!)
--Mike
> -----Original Message-----
> From: owner-ag-announce at mcs.anl.gov
> [mailto:owner-ag-announce at mcs.anl.gov]On Behalf Of Ivan R. Judson
> Sent: 22 February 2003 01:15
> To: ag-announce at mcs.anl.gov; ag-tech at mcs.anl.gov
> Subject: AGTk 2.0 alpha 3 Available
> The Access Grid Toolkit v.2.0-alpha-3 is available for download.
> Components that have been updated since 02/14/2003:
> globus (windows only)
> The Access Grid Toolkit (windows and linux)
> New Requirements since 02/14/2003:
> The python logging module (windows and linux)
> Known Issues:
> Node Management
> - No services are found. (linux only) (Bug 49)
> Workaround: Start AGNodeService.py from /usr/share/AccessGrid
> - The services list may not update after adding a service.(Bug 53)
> Workaround: Click on View/Update and then on then rechoosing the host
> refreshes this list
> - Loading a config fails with "No such file or directory". (linux
> only) (Bug
> 54)
> - VideoProducerService fails to find a configured device. (linux
> only) (Bug
> 58)
> Workaround: Run SetupVideo.py from /usr/share/AccessGrid and start
> AGServiceManager.py from /usr/share/AccessGrid.
> - Installing with one network connection and then later trying to
> run with a
> different network active fails. (Bug 79) (windows only)
> Media Tools
> - rat does not start when entering a venue (Bug 65) (linux only)
> - QuickCam 4000 produces garbage video (Bug 66) (linux only)
> Venue Server
> - Enter venue fails. (Bug 21)
> - Address already in use error. (Bug 22)
> - Starting 2 venues on 2 different ports fails. (Bug 28)
> - No static addressing. (Bug 44)
> - IP address mask set wrong. (Bug 64)
> - Can't have more than 20 venues (Bug 72)
> - Venue server cause client and node management to hand (Bug 77)
> - Venue server hangs if telnetted into and fed garbage (Bug 81)
> Venue Client
> - Tries to connect to bogus test.com on startup (Bug 62)
> - "Local echo" cause exception in PyText (Bug 68)
> - VenueClient process doesn't end after UI closes (Bug 70)
> - Upload file dialog unreadable (Bug 71)
> - Profile info window not in foreground (Bug 75)
> - vic and rat don't start on entry (Bug 76)
> Workaround: leave and re-enter venue
> - Crashes when closing if never connected to venue (Bug 80)
> Fixes Since 02/14/2003:
> - Bug 19
> - Bug 35
> - Bug 39
> - Bug 41
> - Bug 42
> - Bug 43
> - Bug 46
> - Bug 48
> - Bug 51
> - Bug 52
> - Bug 57
> - Bug 59
> - Bug 61
> - Bug 63
> - Bug 82
> Reporting Bugs:
> To report any bugs or feature requests, please use our bugzilla server at
> http://bugzilla.mcs.anl.gov/accessgrid
> Getting the Software:
> To download the software go to
> http://www.mcs.anl.gov/fl/research/accessgrid/software and follow the
> instructions there.
> The AGTk Team
