[AG-TECH] PowerPoint in AG 2.0
He, Yuan
heyuan at ku.edu
Wed Feb 19 20:03:47 CST 2003
Anthony,
RPPT is not compatible with DPPT since the design of the messages for
communication is different and more complicated. It requires using a RPPT
master, a RPPT server and RPPT clients. The current version is available for
downloading at http://plainsman.engr.ku.edu/ag/rppt/rppt.zip. Its
documentation can be found at
http://www.accessgrid.org/agdp/documentation-index.html.
--Eric
Yuan (Eric) He
Chemical and Petroleum Engineering Department
The University of Kansas
4006 Learned Hall, Lawrence, KS66045
Phone: 785-864-2937
Mobile: 785-979-2705
Fax: 785-864-4967
-----Original Message-----
From: Steve Gallo [mailto:smgallo at ccr.buffalo.edu]
Sent: Wednesday, February 19, 2003 5:29 PM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] PowerPoint in AG 2.0
Is RPPT compatible with DPPT to the point where I can use it
to join a presentation where the presenter is using DPPT?
Steve
----- Original Message -----
To: "Milinowicz, Anthony [NCSUS]" <amilinow at NCSUS.JNJ.COM>
Cc: <ag-tech at mcs.anl.gov>
Sent: Wednesday, February 19, 2003 6:18 PM
> Anthony,
> The next version of Distributed Powerpoint called Remote PowerPoint (RPPT)
> is available and in my opinion seems stable enough for download and usage
> (note, I have not really stress-tested it yet...but it seems to work
> well).
> Some nice features include using GUI for setup (no more config file) and
> embedded animations and video are permitted in slides.
> Boston University had a seminar on RPPT many times already. You can view
> the slides at: http://scv.bu.edu/accessgrid/seminars/archives.html.
> Allan
> EVL at UIC
> node-op
> On Wed, 19 Feb 2003, Milinowicz, Anthony [NCSUS] wrote:
> > Has anyone thought of making any changes to the current PowerPoint
solution
> > for AG 2.0? The current way of using this seems generally unstable and
not
> > user friendly. Any ideas?
> > Thanks,
> > Anthony Milinowicz
> > Johnson & Johnson NCS
> > amilinow at ncsus.jnj.com <mailto:amilinow at ncsus.jnj.com>
