[AG-TECH] New hardware specification for AG 2.0?
Lawrence A. Rowe
Rowe at bmrc.berkeley.edu
Wed Feb 19 20:01:59 CST 2003
Hi -
We have been using the Canon VC-C4 pan/tilt cameras. They work fine and
have gotten relatively inexpensive. I just bought one on the web for
$800.
One thing we also did that improved the quality of the images produced
by vic on Linux dramatically -- use an s-video cable from the camera to
the capture card. most capture cards have both a composite and an
s-video connector. We are using Bt878 cards with Video4Linux. The
composite signal had chrominance shift in high frequency signals. The
s-video signal was noticably better. The bottom line is that you should
wire up using s-video where ever possible.
You can see the difference if you go to the BMRC room off the
institutional lobby - or just run
vic 233.2.171.164/59634
i will put two streams showing the Berkeley logo -- one with composite
and one with s-video so you can compare. (I have to go downstairs and
turn it one correctly...)
And, if you're in desparate need of a cheap UTC clock, we usually leave
one camera pointing at our clock... :)!
Larry
Professor Lawrence A. Rowe Internet: Rowe at BMRC.Berkeley.EDU
Computer Science Division - EECS Phone: 510-642-5117
University of California, Berkeley Fax: 510-642-5615
Berkeley, CA 94720-1776 URL: http://bmrc.berkeley.edu/~larry
