[AG-TECH] Running Venues Server Alpha2
Ti Leggett
leggett at mcs.anl.gov
Mon Feb 17 09:21:51 CST 2003
Steps to run a Venue Server:
Get a valid globus proxy (grid-proxy-init)
run VenueServer.py
run VenueManagement.py
run VenueClient.py to connect to you Venue Server
Hope that helps!
On Mon, 2003-02-17 at 08:16, Michael Daw wrote:
> I've downloaded and installed the RPMs AccessGrid-2.0alpha-2.i386.rpm and
> AccessGrid-VenueServer-2.0alpha-2.i386.rpm.
> I'm not sure what I need to do to run the Venue Server.
> Here's what I guessed at:
> Run /usr/bin/VenueManagement.py
> This gets me an interesting looking GUI. When I press 'Go', these are the
> last few lines of output:
> File
> "/var/tmp/pyGlobus-cvs/usr/lib/python2.2/site-packages/pyGlobus/io.py", line
> 658, in connect
> pyGlobus.io.GSITCPSocketException: authentication failed:
> Problem with local credentials
> GSS status: major:00070000 minor: 000003fd token: 00000000
> I didn't want to report a bug, because I suspect there's something I should
> be doing before this ("authentication failed" seems like a giveaway...).
> _______________________________________________________
> Michael Daw
> SVE Group (Supercomputing, Visualization and e-Science)
> Manchester Computing, Kilburn Building,
> University of Manchester, Manchester M13 9PL, UK
> Tel: +44 (0)161 275 7026
> Fax: +44 (0)161 275 6800
> Email: michael.daw at man.ac.uk
> http://www.sve.man.ac.uk/General/Staff/daw
Ti Leggett <leggett at mcs.anl.gov>
