[AG-TECH] 2.0-alpha-2 Announcement *Draft*
Ti Leggett
leggett at mcs.anl.gov
Fri Feb 14 21:36:28 CST 2003
The Access Grid Toolkit v.2.0-alpha-2 is available for download.
Components that have been updated since 02/04/2003:
gpt (linux only)
globus (windows and linux)
pyGlobus (windows and linux)
New Components since 02/04/2003:
The Access Grid Toolkit (windows and linux)
Known Issues:
Node Management
- The services list may not update after adding a service.(Bug 53)
Workaround: Click on View/Update and then on then rechoosing the host
refreshes this list
- No services are found. (linux only) (Bug 49)
Workaround: Start AGNodeService.py from /usr/share/AccessGrid
- VideoProducerService fails to find a configured device. (linux only)
(Bug 58)
Workaround: Run SetupVideo.py from /usr/share/AccessGrid and start
AGServiceManager.py from /usr/share/AccessGrid.
- Loading a config fails with "No such file or directory". (linux only)
(Bug 54)
Media Tools
- vic starts with wrong ttl (Bug 51)
Venue Server
- Enter venue fails. (Bug 21)
- Address already in use error. (Bug 22)
- Starting 2 venues on 2 different ports fails. (Bug 28)
- No static addressing. (Bug 44)
- A shutdown on a restarted venue fails. (Bug 59)
Reporting Bugs:
To report any bugs or feature requests, please use our bugzilla server
at http://bugzilla.mcs.anl.gov/accessgrid
Getting the Software:
To download the software go to
http://www.mcs.anl.gov/fl/research/accessgrid/software and follow the
instructions there.
Ti Leggett <leggett at mcs.anl.gov
