[AG-TECH] VRM and ARM Missing HeartBeat
Rod Harris
rod.harris at anu.edu.au
Thu Feb 13 22:35:42 CST 2003
I have encountered a problem with the VRM and ARM event listeners not
getting the heartbeat from the display machine.
When I run vrm-eventlistener it claims it has connected to the display
machine (I've made sure all the scripts in /usr/local/ag/lib point to the
correct machine, and followed the advice from previous postings to this
list) but I get no heartbeat.
I've also tried running the arm-eventlistener on this machine but it also
gets no heartbeat.
However, when I run the arm-eventlistener on the audio machine I do get a
heartbeat (until I enter a room, at which time RAT will load up properly
but I'll loose the heartbeat).
I've tried using different JVMs (1.2.2, 1.2.2-14, 1.4.1-01) but that makes
no difference.
I've tried copying the scripts from the audio machine to the video machine,
but it still doesn't work.
And finally I booted the video machine into Windows and ran the VRM from
there and it does get the heartbeat.
I get this message when running the vrm-eventlistener (from Linux):
Missed heartbeat!
Mssed a second heartbeat, trying reconnect
disconnect sdp channel listener
Got newstate false
create listener
Got event channel
org.omg.CosEventChannelAdmin.StubForEventChannel:com.ooc.CORBA.Delegate at 84ce7a
Got newstate true2
reconnect succeeded!
and the display machine prints:
cache returns sdp
The video machine is a dual Xeon running RH8.0.
Rod
