[AG-TECH] Entry for Osprey 210 card in video-conf.
Jimmy Miklavcic
jhm at chpc.utah.edu
Thu Feb 13 13:44:05 CST 2003
Thanks for all that helped. It appears that there is a misunderstanding
of the ports. The only port that I could get to work is the composite
port but I had to select the Television port name to do so. I have not
been able to get the s-video port to work. So, for now, the Osprey 210
is working along side the Hauppauge cards. Connection from the camera is
composite and the port setting is Television. We are now running four
cameras.
Jimmy
Robert Olson wrote:
> It may mean that the mapping of port names isn't right with this card;
> have you tried switching to different input ports?
> At 10:30 AM 2/7/2003 -0700, Jimmy Miklavcic wrote:
>> I'm getting a blue screen. This indicates that the chip is active but
>> it's not passing the camera video through. Is this correct?
Jimmy Miklavcic
Multimedia Specialist
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.chpc.utah.edu/~jhm
http://www.anotherlanguage.org
