[AG-TECH] RE: Installing the Venues Server
Ivan R. Judson
judson at mcs.anl.gov
Wed Feb 12 11:35:04 CST 2003
I thought you were going home :)
--Ivan
PS -- yeah, cc ag-tech
> -----Original Message-----
> From: Michael Daw [mailto:mike.daw at man.ac.uk]
> Sent: Wednesday, February 12, 2003 11:07 AM
> To: Ti Leggett; judson at mcs.anl.gov
> Subject: RE: Installing the Venues Server
> These are the things holding me up on my installation:
> 1. The certificate request procedure says I should receive my
> certificate within 2 days. It's about 2.5(!). Any news?
> 2. Ivan's point 4 below says, "Get the AccessGrid Python
> Module installed". Do I take it that this is setup.py? Also,
> how do I install it? I've been trying stuff in
> http://www.python.org/doc/tut/ with no luck. (You need to
> know I've never used python before...) I'd consult the
> documentation, but I'm supposed to be writing it...
> --Mike
> PS Is this the kind of thing you want cc-ed to ag-tech? If
> so, feel free to cc it on your reply and I'll do so in future.
> > From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
> > Sent: 10 February 2003 12:33
> > To: 'Michael Daw'; 'Robert Olson'; 'Ti Leggett'
> > Cc: 'Jennifer Teig von Hoffman'
> > Hey Michael;
> > I've been running a venue server by hand each time I've
> been testing.
> > It should be fairly simple to do.
> > Here are the steps starting at the beginning:
> > 1) Get GT2.0 installed
> > 2) Get pyGlobus installed
> > 3) Get your certificates installed
> > 4) Get the AccessGrid Python Module installed
> > 5) cd AccessGrid/bin and run VenueServer.py (if permissions
> aren't set
> > right you might have to run python VenueServer.py).
> > 6) in AccessGrid/bin run VenueManagement.py
> > in the address bar type in
> https://<host>:8000/VenueServer and press
> > go.
> > the <host> should be the host you ran the VenueServer
> on, and *if*
> > you changed the default port for the server you'll
> have to change the
> > 8000 to your port. Then you should be able to add,
> remove and modify
> > venues.
> > *** one of the changes to the venue management ui last
> Friday was the
> > ability to Put exits that go from venues on one server to
> venues on a
> > different server,
> > this might be interesting to you ***
> > If this doesn't work, can you send me the output? I'd like to see
> > what's happening. You might also want to get the latest copy from
> > CVS, there have been moderate changes to everything (Hold
> on to your
> > Hats, this is the breezy part! :-).
> > --Ivan
> > PS -- Don't be shy; push on it. We're not going to bite. We should
> > probably also have this discussion on AG-tech so others can benefit
> > (although agdp'ing it will help a lot)
> > > Sent: Monday, February 10, 2003 6:23 AM
> > > To: Robert Olson; Ivan R. Judson; Ti Leggett
> > > Cc: Jennifer Teig von Hoffman
> > > Subject: Installing the Venues Server
> > > Bob / Ivan / Ti,
> > > As you probably know, I'm trying to install the AG2.0
> Venues Server.
> > > I kind of got the impression from the last Town Hall
> meeting that it
> > > was ready for a user such as me to do this and start
> playing around
> > > with it, but now I'm thinking I may be wrong.
> > > Please either:
> > > 1. Tell me to back off because you're still working on it
> and it'll
> > > never get done if people like me keep hassling you(!).
> > > 2. Give me some guidance on installation. There's no installation
> > > document on the web and the AccessGrid/INSTALL file on
> CVS is empty.
> > > I've had a look around, but it's difficult to know where
> to start.
> > > (I've installed all the prerequisite software and
> requested a Globus
> > > certificate, so I need help with the AGTk bits that come
> > > afterwards.)
> > > If you want to fire off instructions to me the best you can (e.g.
> > > e-mails/whatever), I don't mind using them to write a pretty
> > > installation / setup document so that people who will
> follow me on
> > > this path are well-served. I don't mind getting my hands dirty.
> > > But feel free to do option 1 above! (Although it might be
> useful to
> > > know when I *can* start - my primary motivation for this is SC
> > > Global...).
> > > --Mike
> > > _______________________________________________________
> > > Michael Daw
> > > SVE Group (Supercomputing, Visualization and e-Science)
> > > Manchester Computing, Kilburn Building,
> > > University of Manchester, Manchester M13 9PL, UK
> > > Tel: +44 (0)161 275 7026
> > > Fax: +44 (0)161 275 6800
> > > Email: michael.daw at man.ac.uk
> > http://www.sve.man.ac.uk/General/Staff/daw
