[AG-TECH] Network Flow diagrams
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Tue Feb 11 04:14:15 CST 2003
Bob,
Many thanks for that - it may solve the problem we're having -
failure to be a DPPT server although we can be master and client!
I'll add the info to my 'document'.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
Sent: 10 February 2003 16:42
To: Osland, CD (Chris) ; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Network Flow diagrams
At 11:46 AM 1/30/2003 +0000, Osland, CD (Chris) wrote:
>Following on from what Phil and then Andrew put together,
>I've formatted a Word document which is perhaps easier to read
>and has added info about DPPT and RPPT - which hopefully I've
>understood enough to get in the right place.
hi -
we just ran into this problem after MCS put up a more restrictive firewall.
There are two ports that need to be opened incoming to the server:
4561 for the JSDT Registry, and
5001 for the DPPT server itself
port 80 doesn't need to be opened to the dppt server itself, unless there
is actually an http server running on it.
clients don't need to have any incoming connections open; they make
outgoing connections to the two ports listed above on the server.
thanks,
--bob
