[AG-TECH] Entry for Osprey 210 card in video-conf.
Ti Leggett
leggett at mcs.anl.gov
Fri Feb 7 12:21:52 CST 2003
If you're using linux, you'll need to use the osprey drivers. I've no
idea if those drivers will screw with regular Hauppage cards. My
instinct is no, that it probably just extends the bttv driver to
recognize the break out box.
I'm interested to hear the outcome.
On Fri, 2003-02-07 at 10:58, Jimmy Miklavcic wrote:
> It picked up the card as a Hauppage card instead of the Osprey. Do I
> need to load bttv-0.7.91-osprey-rc1 and if so, will that just add the
> osprey drivers without over-writing the Hauppage drivers?
> Jimmy
> Robert Olson wrote:
> > If you run setup-config it will determine the right string and insert
> > it into the config file.
> > --bob
> > At 09:19 AM 2/7/2003 -0700, Jimmy Miklavcic wrote:
> >> The entry for the hauppage cards in the video-conf file is:
> >> <capture_card device="v4l- BT878(Hauppauge new) /dev/video2"....
> >> What's the equivilant for the Osprey 210?
Ti Leggett <leggett at mcs.anl.gov>
