If you run setup-config it will determine the right string and insert it into the config file. --bob At 09:19 AM 2/7/2003 -0700, Jimmy Miklavcic wrote: >The entry for the hauppage cards in the video-conf file is: > > <capture_card device="v4l- BT878(Hauppauge new) /dev/video2".... > >What's the equivilant for the Osprey 210?
