[AG-TECH] Testing
    Jon I Johansson
    jon.johansson at ualberta.ca
    Thu Aug 28 13:05:12 CDT 2003
Never mind, I found the transmit button. Now I show up in
beautiful reds and greens - I'll check more menus.
Jon.
Jon I Johansson             *  Research Computing Support
jon.johansson at ualberta.ca   *  Computing and Network Services
Tel.: (780) 492-9304        *  University of Alberta
Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
-----Original Message-----
From: Jon I Johansson [mailto:jon.johansson at ualberta.ca]
Sent: Thursday, August 28, 2003 11:51 AM
To: 'Paul Mercer'
Cc: 'ag-tech at mcs.anl.gov'
Subject: RE: [AG-TECH] Testing
Thanks Paul,
I was reminded that I had to be at home so I shut down.
I have 2 nodes in the Test Room, using 2.1.1b and I can
talk back and forth just fine, but I don't get any video.
Rat shows 2 entries for me in the test room along with
two other nodes but I'm not showing up on vic.
Any ideas on what I might need to configure to get
a video feed? I tested the video capture with Netmeeting
and it works just fine there.
Jon.
From: Paul Mercer [mailto:mercer at mailhost.arsc.edu]
Sent: Wednesday, August 27, 2003 6:03 PM
To: Jon I Johansson
Subject: Re: [AG-TECH] Testing
Iam in the test room now but do not see you .  I also just installed
2.1.1b but can't get the shared apps working.
Paul
ARSC AGlaptop pig
>If anyone is in the test room could you wave at me if you see video
>from jonj? I just installed AGTk 2.1.1b and things seem to be wirking
>much better now.
>Thank you,
>Jon.
