[AG-TECH] VenueClient unable to load default config
Robert Olson
olson at mcs.anl.gov
Mon Aug 18 09:40:12 CDT 2003
Did you uninstall the old winglbous installation before installing 2.1? the
following in the logfile makes me think the app is seeing the old pyglobus
install. get_certificate_locations is new in the 2.1 pyglobus.
Traceback (most recent call last):
File "/usr/bin/VenueClient.py", line 119, in __init__
self.app = Toolkit.WXGUIApplication()
File "/usr/lib/python2.2/site-packages/AccessGrid/Toolkit.py", line 141,
in __init__
self.gui)
File
"/usr/lib/python2.2/site-packages/AccessGrid/CertificateManager.py", line
249, in __init__
self.InitializeRepository()
File
282, in InitializeRepository
self.InitRepoFromGlobus(self.certRepo)
File
300, in InitRepoFromGlobus
certLocations = pyGlobus.sslutilsc.get_certificate_locations()
AttributeError: 'module' object has no attribute 'get_certificate_locations'
--bob
At 09:56 AM 8/18/2003 -0400, Frank Sweetser wrote:
>(I would bugzilla this, but there isn't an entry for 2.1 yet)
>AccessGrid 2.1 installed, running on RedHat 9. Blew away ~/.AccessGrid, but
>left ~/globus alone. On the first run, it hangs and has to be killed
>manually.
>On the second run, it gets further, but dies and hangs after trying to load
>the default config. Here's the traceback
> File "/usr/bin/AGNodeService.py", line 141, in ?
> nodeService.LoadDefaultConfig()
> File "/usr/lib/python2.2/site-packages/AccessGrid/AGNodeService.py",
> line 84, in LoadDefaultConfig
> raise Exception("Failed to load default configuration %s"
> %self.defaultConfig)
>Exception: Failed to load default configuration defaultLinux
>I've also attached the VenueClient.log file.
>Frank Sweetser fs at wpi.edu
>WPI Network Engineer
