[AG-TECH] AG Venue Access Control
Stuart Levy
slevy at ncsa.uiuc.edu
Wed Aug 13 11:31:32 CDT 2003
On Wed, Aug 13, 2003 at 10:39:22AM -0500, Ivan R. Judson wrote:
> Hey Stuart,
> Good questions. What it does is creates an authorization step in venue
> entry. What that means is if you aren't allowed in the venue, you don't get
> to know anything about the contents (including the stream information).
> If using dynamic streams this means you don't get to know the stream
> locations or encryption keys (because they're dynamically allocated). If you
> are using static streams, then the addresses could be known. Eventually
> (when the media tools are reasonable) we'll be adding an encryption rollover
> mechanism that issues new keys at an interval (might be random?), so that
> even if you know the stream locations, you won't know the keys to get at the
> data.
> Does that make sense?
Yes, that sounds great. Thanks for the explanation, Ivan.
Stuart
