[AG-TECH] AccessGrid 2.0 in Slackware 9.0
Christoph Willing
chris at vislab.usyd.edu.au
Sun Aug 10 19:04:01 CDT 2003
On Fri, 2003-08-08 at 10:42, Christoph Willing wrote:
> On Fri, 2003-08-08 at 04:26, Stephen Bosch wrote:
> > I'm attempting to install the AccessGrid packages in Slackware 9.0.
[]snip
> I think you'll find compiler issues with rat as well - I've been able to
> make it compile with gcc3.2.2 but when I run it, no ui comes up. Under
> gcc2 it compiles & runs fine.
Belay that. I've just tried again and it compiles & runs OK
(AccessGrid-rat-4.2.22-2.src & gcc3.2.2 on Slack 9).
BTW the current binary rpm of rat does _not_ have ALSA support. The code
is there but not enabled. The rat configure script looks for ALSA 0.5
libraries before enabling it, so evidently the binary was compiled on a
machine without ALSA 0.5. I'm not sure if this is considered a bug?
On the subject of ALSA, people are probably aware that ALSA is the
default audio in Linux 2.6 (there's a test3 version now available). The
API is quite different to that used for ALSA support in the current rat
code. We've had someone working on rat to support the new API and a
working version is being tested. We're hoping to release a beta for
wider testing later this week.
chris
Chris Willing Telephone (61-2) 9351 3914
VisLab, A28 Facsimile (61-2) 9351 7726
University of Sydney
NSW 2006 Australia http://www.vislab.usyd.edu.au
