[AG-TECH] beacon, vtc, multicast???
    Robert Olson
    olson at mcs.anl.gov
    Fri Aug  8 10:01:05 CDT 2003
The use of 7777 is historical; moo servers have used that by default for a
long time.
I'm reluctant to just change the port it's listening on. I think I've
figured out how to add another port; are there any others in that range
that folks know are commonly blocked? I'll have to get the firewall folks
here to open up a conduit for this before it'll be usable.
What you can do now is connect using the MOO proxy server running on the
same host, port 7779.
--bob
At 10:46 AM 8/8/2003 -0400, Moses, Jennifer (Cont,ARL/CISD) wrote:
>We have been trying to use the PIG 1.2 here at the Army Research
>Laboratory for a while, and finally discovered the problem with 7777.
>Until moo uses another port, we are unable to use the PIG software
>properly since ARL blocks port 7777 and there's essentially no hope of
>getting it unblocked. I, for one, whole heartedly support the port
>number being changed.
