[AG-TECH] AccessGrid 2.0 in Slackware 9.0
    Eric Olson
    eolson at mcs.anl.gov
    Thu Aug  7 14:23:43 CDT 2003
Stephen,
If you want a safe version of the AccessGrid code from cvs, you can
checkout the 2.0 branch.
  cvs co -r r_2_0_final AccessGrid
When the 2.1 release comes out, there will be a similar branch.
This is recommended over using the main branch -- where the code is always
under development and can be unstable.
Eric
On Thu, 7 Aug 2003, Stephen Bosch wrote:
> Hi, Ivan:
> Thanks for the quick response!
> Ivan R. Judson wrote:
> >>I'm attempting to install the AccessGrid packages in Slackware 9.0.
> >>First -- I'd like to point out the folly of providing the source
> >>packages in RPM format only. That doesn't count as "source"
> >>-- that's a
> >>source RPM. Sources should be in generic tar.gz packages.
> > We have that in our list of things to do; however you can always get the
> > code from cvs as well. That would avoid the RPM issue.
> I'm always nervous about pulling stuff from cvs for obvious reasons, but
> if people are having success running out of cvs then I don't have a
> problem with that :)
> I would be happy to make a set of Slackware packages and contribute them
> to the project; I just need to know if there are any directory structure
> peculiarities. Ideally I'd like to make one big package that installs
> all the components.
> Before I do that, though, I'll get a from-source build running properly.
> > It looks to me like the configure script is detecting you have quickcam
> > support. That would happen if you have /usr/local/lib/libqcam.a, or
> > /dev/qcam0, or have specifically specified the directory for the code (which
> > I'm guessing you didn't do).
> Nope, though I did do the quick and complete install of Slackware, so
> it's possible Quickcam support is in.
> > Why don't you try reconfiguring using something like --without-qcam to
> > explicitly disabling this?  Does slackware include the libraries?
> It might -- perhaps the install script just isn't looking in the right
> place.
> There's no configure script for the vic sources, I noticed. Is that any
> different in CVS?
> -Stephen-
> Stephen Bosch
> Collaborative Systems Specialist
> Netera Alliance Inc.
> Biosciences 530B
> 2500 University Dr NW
> Calgary AB T2N 1N4
> tel (403) 220 2546
> fax (403) 282 0838
