[AG-TECH] AG connection problems (AGServicemanager)
Alexander Kuzan
kooz at gmx.net
Tue Aug 5 15:36:56 CDT 2003
hi todd
I think I figured out what the problem was. I'm not sure, but I'll post it here anyway, as I think it might be helpful to you and others.
The problem was caused, as you said, by the grid-proxy certificate being expired (or seeming to be expired for the venue machine). In my case that was cause by a major difference in system times of the participating systems. I installed a ntp daemon and had all systimes updated and kept in synch. After that I never ran into the same problem again (apart from ntp not updating the BIOS clock) it seemed to work perfect.
I thank you for you reply and hope this might be of some help to you too.
alex
On Tue, Aug 05, 2003 at 11:17:23AM -0700, Todd Zimmerman wrote:
> Hi Alex,
> We also have run into this issue; however, I can't seem to reproduce it
> consistantly enough to file a bug report. It _appears_ as though it happens
> after running grid-proxy-init on the linux side after the certificate has
> expired. I'll try to confirm that so that we can file a report.... FYI, we
> are also running RH7.3 on our capture box, so I'm unsure if this is 7.3
> specific.
> Todd Zimmerman
> -----Original Message-----
> From: Alexander.Kuzan at gmx.net [mailto:Alexander.Kuzan at gmx.net]
> Sent: Mon 04-Aug-03 12:51 AM
> To: ag-tech at mcs.anl.gov
> Cc:
> Subject: [AG-TECH] AG connection problems (AGServicemanager)
> hi everyone
> I'm a computer science master at the university of switzerland in
> zurich and
> I'm setting up a test environment with two AG nodes. I have the
> systems up
> and running, I did a standard
> +installation of RH7.3 with all updates as of today (Mon Aug 4
> 09:42:15
> CEST 2003) and I installed the AGTK 2.0 from the main AG site.
> got a certificate, created grid-proxies and all on all the machines,
> and
> started AGServiceManager.py on all of them (1 audio, 1 video, 1
> display). now my
> problem:
> when I run the AGNodeService.py and the NodeManagement.py on either
> windows
> or linux, and try to connect the audio and video machines, I
> sometimes get an
> error:
> Exception: Service Manager is unreachable
> https://audio1:12000/ServiceManager
> but it's not on all machines, and it's not all the time. I don't know
> what
> it is... can somebody help me with this ?
> for instance, I can connect to the audio machine, but the video
> machine is
> unreachable, and the other way around.
> see the log of the agsm below
> thank you for your time and effort
> I really appreciate it
> alex
> 08/04/2003 09:40:24 AM ERROR AddServiceManager: Invalid service
> manager url
> (https://video1:12000/ServiceManager)
> Traceback (most recent call last):
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/AGNodeService.py", line
> 123, in AddServiceManager
> Client.Handle( serviceManager.uri ).IsValid()
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/Client.py",
> line 79, in IsValid
> ret = proxy._IsValid()
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py",
> line 3650, in __call__
> return self.__r_call(*args, **kw)
> File
> line 3670, in __r_call
> self.__hd, self.__ma)
> File
> line 3570, in __call
> config = self.config)
> File
> line 184, in call
> r.endheaders()
> File "//usr/lib/python2.2/httplib.py", line 695, in endheaders
> self._send_output()
> File "//usr/lib/python2.2/httplib.py", line 581, in _send_output
> self.send(msg)
> File "//usr/lib/python2.2/httplib.py", line 548, in send
> self.connect()
> File "/usr/lib/python2.2/site-packages/pyGlobus/io.py", line 1079,
> in
> connect
> self.sock.connect(self.host, self.port, self.io_attr)
> File "/usr/lib/python2.2/site-packages/pyGlobus/io.py", line 663,
> in
> connect
> raise ex
> GSITCPSocketException: authentication failed:
> Authentication Failed
> GSS status: major:000a0000 minor: 00000000 token: 00000000
> 08/04/2003 09:40:24 AM ERROR Exception 'Service Manager is
> unreachable:
> https://video1:12000/ServiceManager' in call to <bound method
> AGNodeService.AddServiceManager of
> +<AccessGrid.AGNodeService.AGNodeService instance at 0x86f352c>>
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/hosting/AccessControl.py", line
> 292, in __call__
> rc = self.callback(*args)
> File
> 127, in AddServiceManager
> raise Exception("Service Manager is unreachable: "
> Exception: Service Manager is unreachable:
> COMPUTERBILD 15/03: Premium-e-mail-Dienste im Test
> 1. GMX TopMail - Platz 1 und Testsieger!
> 2. GMX ProMail - Platz 2 und Preis-Qualitätssieger!
> 3. Arcor - 4. web.de - 5. T-Online - 6. freenet.de - 7. daybyday - 8.
> e-Post
