[AG-TECH] Access Grid Toolkit 2.0 Release Candidate 1 Available
    Ivan R. Judson
    judson at mcs.anl.gov
    Tue Apr 29 18:10:21 CDT 2003
The Access Grid Toolkit 2.0 Release Candidate 1 is available for download
at:
http://www.mcs.anl.gov/fl/research/accessgrid/software/2.0-rc1/index.html
Please download and try the release candidate, feedback can be provided
either through bugzilla and/or the ag-tech mailing list. Please provide
feedback, pointers to information, or other pertinent information for us
to incorporate into the next release candidate and/or final!
In order to use the Transitional Venue Server you MUST upgrade to RC1.
The AG Team
Release Notes
This release requires an upgrade to work correctly.
Known Issues:
General
If your proxy expires while in a venue you cannot exit, you must kill the
client manually.
Installation
Installation of Shared Browser and Presentation is not complete.
Installation of Personal Node Support has not been finished for Linux, to
use this run the command: VenueClient.py --personalNode
Media Tools
There is a set of known issues with the media tools, related to startup,
control and shutdown. These are blocking on a better interface for
controlling the tools.
Node Management
The default configuration installs an AudioService and a
VideoConsumerService to produce video you must install a
VideoProducerService by hand through the Node Management User Interface.
This is found through the My Node menu in the venue client.
