Fwd: [AG-TECH] How to configure VRM of PIG? (Re: USB camera  with PIG (AG 1.1))
    Michael Miller
    mimiller at ncsa.uiuc.edu
    Tue Apr 22 13:29:56 CDT 2003
Found this on MS website:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dndevice/html/vfwmap.asp
Provides info about mapping VFW to WDM
MYK
>X-Envelope-From: mimiller at ncsa.uiuc.edu
>X-Envelope-To: <ag-tech at mcs.anl.gov>
>X-Sender: mimiller at pop.ncsa.uiuc.edu (Unverified)
>X-Mailer: QUALCOMM Windows Eudora Version 5.1
>Date: Tue, 22 Apr 2003 09:21:39 -0500
>To: ag-tech at mcs.anl.gov
>From: Michael Miller <mimiller at ncsa.uiuc.edu>
>Subject: Fwd: [AG-TECH] How to configure VRM of PIG? (Re: USB camera
>   with PIG (AG 1.1))
>X-Spam-Status: No, hits=1.9 required=5.0
>tests=SUBJ_HAS_Q_MARK,PORN_11,PORN_10 version=2.21
>X-Spam-Level: *
>Sender: owner-ag-tech at mcs.anl.gov
>X-MD5SUM: 1180dc5c1419111fcee97475eccbdc56
>Kazuyuki,
>I just solved a problem with VRM and video-config with the help of folks
>both at Argonne and here at NCSA.
>To discover what should be written in the video-config file, start your
>pig the normal way and get into a venue.  You should at least get one
>instance of vic from the DRM.  click the "Menu" button to open the
>"vic:vic menu" dialog.  Click the "Devices" button to drop down a list of
>the video devices that vic can see.  You should have an entry for each
>device listed in your video-config file.  for example in my "Devices" list
>I have:
>Microsoft WDM Image Capture (Win32)
>so I put a line in my video-config file like this:
><capture_card input="Composite1" number="0" purpose="PRESENTER"
>device="Microsoft WDM Image Capture (Win32)"/>
>This works for my Logitech Quickcam 4000.  If more devices are listed, you
>should add more lines similar to the above with the "device=" portion
>matching what you find in the "Devices" list in vic.  The string
>"Microsoft WDM Image Capture (Win32)" represents the newer media driver
>architecture.  Some devices do not have proper drivers but will work
>because the WDM architecture provides for backwards compatibility.  The
>caveat is that, if you have more than one legacy device, (i.e. "Microsoft
>WDM Image Capture (Win32)" is listed more than once in vic) then you may
>not be able to choose between devices and vic may crash if you select the
>wrong device.  The solution found by Shawn Davis was to download an older
>set of VFW drivers that vic can see independent of the WDM
>architecture.  In setting up several machines, I have found that
>installing drivers for WDM devices first, then installing drivers for VFW
>seems to work best.
>Also, be sure that the hostname is correct in the video-config or the VRM
>will not correctly parse the video-config file.  For a while I had this in
>my video-config file:
>  <ag_node name="copland">
>   <capture_computer name="copland">
>but this did not work.  I found out from Justin Binns(ANL) that this needs
>to match the result of the Java gethostname function call.  I was able to
>obtain the proper string by using "ipconfig /all" at a DOS prompt to find
>the hostname.  I now have:
>  <ag_node name="Copland">
>   <capture_computer name="Copland">
>Note the capital "C".  Everything works fine now.
>I can't guarantee that "ipconfig /all" will give you the proper setting,
>but hopefully this will lead you in the right direction.
>Anyone else have comments, corrections?
>Michael Miller
>NCSA
>>X-Envelope-From: owner-ag-tech at mcs.anl.gov
>>Date: Tue, 22 Apr 2003 11:08:58 +0900 (JST)
>>Subject: [AG-TECH] How to configure VRM of PIG? (Re: USB camera with PIG
>>(AG 1.1))
>>From: shudo at ni.aist.go.jp
>>X-Mailer: Mew version 2.2 on XEmacs 21.4.8 (Honest Recruiter)
>>X-Spam-Status: No, hits=-2.0 required=5.0
>>tests=IN_REP_TO,SUBJ_HAS_Q_MARK,NO_REAL_NAME,PORN_11 version=2.21
>>X-Spam-Level:
>>X-MD5SUM: f2df51787a78c57010e2c1ce9e46442f
>>I found a configuration file named video-config in AG 1.2 (PIG).
>>It is dedicated for Osprey capture cards and I could not find a set-up
>>tool for VRM like the setup-config script included in VRM for Linux.
>>How can I write video-config for my USB cameras?
>>Are there any information on how to write it?
>> > From: shudo at computer.org
>> > Date: Fri, 04 Oct 2002 21:44:40 +0900 (JST)
>> > I cannot use a USB camera with the VIC (ddvic.exe and vic.exe) which
>> > PIG has on Windows 2000.  But the camera works well with the UCL
>> > version of VIC, which I obtained at the following web site:
>> >   Videoconferencing Tool
>> >   http://www-mice.cs.ucl.ac.uk/multimedia/software/vic/
>> > The version of the UCL VIC is 2.8ucl-1.1.3.
>> > The USB camera is Creative WebCam Plus.
>>Thanks,
>>   Kazuyuki Shudo
>>   Grid Technology Research Center
>>   National Institute of Advanced Industrial Science and Technology (AIST)
>Thanx,
>Michael Miller
>System Engineer
>Visualization Technology Support
>Computing and Data Management
>National Center for Supercomputing Applications
>University of Illinois - UC
>"If you're clear in your vision and trust the people in your team with
>clear objectives, they will invariably do their best to achieve everything
>desired, and usually deliver everything you could have hoped for and even
>more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
