[AG-TECH] Encryption and the PIG
Shawn Davis
wdavis at ncsa.uiuc.edu
Fri Sep 27 00:18:51 CDT 2002
I have successfully tested using an encrypted venue between my PIG and our
regular AG node. At the time I tested it, I was able to enter ANL's
encryption test room. Maybe they've changed the access permissions on it
since then? I also experimented with adding encryption to our venues on
AGSchedule. Both worked just fine, and I confirmed this by reloading the
same venue without the encryption enabled on one of the nodes, and as
expected, the two nodes could not communicate with each other.
-Shawn
At 08:27 AM 9/26/2002 -0700, Randy Groves wrote:
>Has anyone successfully used the PIG in either the Secure Room or the
>Encryption Test Room?
>I'm running into problems with my local VV implementation, and
>unfortunately don't have access to either of those rooms to test the PIG.
>It's looking like maybe the OpenMash vic might be encryption challenged.
>-randy
