[AG-TECH] Re: some suggestion
Shawn Davis
wdavis at ncsa.uiuc.edu
Wed Oct 30 22:08:27 CST 2002
Hi Kun,
Yes, you're right. According to the RFCs, even numbered ports are to be
used for RTP channels, whereas RTCP is used on the odd-numbered ports.
Those port assignments were assigned to me quite some time ago. Since RAT
and VIC work fine with them, I didn't feel a need to change them.
However, seeing as how the specifications are written, and the possibility
that someday software will be written that won't be so lenient, I have
changed the port numbers to abide by the spec.
Please revisit http://agschedule.ncsa.uiuc.edu/venues.asp to see the new
port numbers.
-Shawn Davis
At 07:14 PM 10/30/2002 -0800, Kun Wei wrote:
>Hello;
>I saw at your page that Virtual Venues is configured as following. How
>does it work?
>Considering that MBone connection will open RTP and RTCP port. For
>example, Axon room, Mbone vic will listen on 26016 and 26017, and MBone
>rat will listen on 26016 and 26017, same port!
>Let us know because we are going to enable VRVS AG gateway based on user
>request.
>Name IP Address Port Media Owner
>Axon 233.4.200.16 26016 video NCSA
>Axon 233.4.200.17 26017 audio NCSA
>Cosmic Voyage 233.4.200.6 21006 video NCSA
>Cosmic Voyage 233.4.200.7 21007 audio NCSA
>Hydrogen 233.4.200.10 23010 video NCSA
>Hydrogen 233.4.200.11 23011 audio NCSA
>Landspout 233.4.200.14 25014 video NCSA
>Landspout 233.4.200.15 25015 audio NCSA
>Monte Carlo 233.4.200.8 22008 video NCSA
>Monte Carlo 233.4.200.9 22009 audio NCSA
>Mosaic 233.4.200.4 20004 video NCSA
>Mosaic 233.4.200.5 20005 audio NCSA
>Optiverse 233.4.200.2 19002 video NCSA
>Optiverse 233.4.200.3 19003 audio NCSA
>Walkabout 233.4.200.12 24012 video NCSA
>Walkabout 233.4.200.13 24013 audio NCSA
> Kun Wei
> Email: weikun at caltech.edu
> Address: MC 256-48, Caltech
> Pasadena, CA 91125
> Phone: 1-626-395-8767
